Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Configuring Tables and Columns > About Data ColumnsData columns comprise most of the columns in Siebel applications. They are sometimes referred to as base columns. Data columns provide the data for fields, or serve as foreign keys that point to rows in other tables. You cannot modify the properties of data columns. Data columns can be public or private. |
Configuring Siebel eBusiness Applications |
