Configuring Siebel eBusiness Applications > Configuring Toolbars and Menus >
Creating a New Toolbar
You can create new toolbars for an application by defining a toolbar object and modifying the appropriate Siebel Web templates to expose the new object in the user interface. You can also add new icons to existing toolbars. To define a new toolbar
- In Types view in the Object Explorer, double-click the Toolbar object type.
- Click to the left of a row in the Object List Editor, and then choose Edit > New Record.
- Specify the name of the new toolbar in the Name property of the new object definition.
- To expose the toolbar to the user interface, you need to add a specific tag to the Container Page or one of its child templates that you are using.
For detailed information on templates and tags, see Siebel Developer's Reference.
