Configuring Siebel eBusiness Applications > Configuring Toolbars and Menus > About Toolbars and Menus >
About Applet Method Menu Item
Defines a menu item in the applet-level menu for the parent Applet object definition. Important properties are the following:
- Menu Text. The text displayed in the menu item.
- Suppress Menu Item. Default is FALSE. If TRUE, causes the class-level menu item of the specified name to be removed from the applet-level menu in the applet where this property is specified.
- Command. Name of the Command object definition that is to provide the bitmap, method, and target for the applet menu item.
- Position. The sequence of the menu item in the single-level list of menu items.
