Configuring Siebel eBusiness Applications > Overview of Web Templates and Siebel Tags >
About Siebel Tags
Siebel tags are special tags you insert into template files. They specify how objects defined in the repository should be laid out and formatted in the final HTML page in the user's Web browser. The process of configuring a Web application separates the layout and formatting from the application definition and binding to data. You use Siebel tags to determine the layout and formatting of controls in your application.
