Siebel Financial Services Connector for IAA-XML Guide > Troubleshooting > Integration Object Setup Issues > Out-of-Sync DatabaseAfter compiling your .srf file and moving it to your test environment you can not locate your integration objects or DTE maps. |
| Siebel Financial Services Connector for IAA-XML Guide |
