Siebel Financial Services Connector for IAA-XML Guide > Siebel Connector for IAA-XML > FINS IAA Wizard > Integration ObjectsSiebel integration objects allow you to represent integration metadata for Siebel business objects, XML, SAP IDOCs, and SAP BAPIs as common structures that the eAI infrastructure can understand. Because these integration objects adhere to a set of structural conventions, they can be traversed and transformed programmatically, using Siebel eScript objects, methods, and functions are transformed declaratively using Siebel Data Mapper. To use the Siebel Connector for IAA-XML to integrate data you need to build three different integration objects. IAA Envelope Integration Object. The Integration Object that defines the envelope and the header portions of the IAA-XML Message. For details, see To Create IAA envelope Integration Objects IAA External Integration Objects. The integration object that defines the IAA-XML data hierarchy. For details, see To create IAA external integration objects. IAA Internal Integration Objects. The integration object that defines the Siebel data hierarchy. For details, see Creating IAA Internal Integration Objects. |
| Siebel Financial Services Connector for IAA-XML Guide |
