Siebel Financial Services Connector for IAA-XML Guide > Overview > Architectural Overview >
Workflow Integration
Siebel Workflow is the center of the business data flow. Workflow processes control the flow and transformation of data into and out of the Siebel applications. You create the workflow processes using a graphical user interface provided within the Siebel applications called the Siebel Workflow Designer. NOTE: For details on Siebel Workflow, see Siebel Business Process Designer Administration Guide
