Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring Runtime Event ManagerSiebel supports triggering workflows based on run time events such as Write Record, which gets triggered whenever a record is written. Using a runtime event allows you to incorporate configured workflow functions into actual applications. NOTE: For details, see Siebel eEvents Management Guide. The example in this section describes a runtime event that triggers a workflow when a new contact record is added by users through Siebel Financial Services Application. In the following procedure, a runtime event as well as the corresponding action is defined.
| Siebel Financial Services Connector for IAA-XML Guide |
