Developing and Deploying Siebel eBusiness Applications > Assignment Manager > Configuring Territory Assignment ComponentsNREC's assignment rules use the ZIP Code attribute on the opportunity to determine how to assign the opportunity. This is a custom attribute that you added to the opportunity business component in Adding Fields to the Opportunity Business Component. Because this is a custom attribute, NREC needs to add a new assignment criteria using Siebel Tools before being able to create assignment rules. This section summarizes the high-level tasks necessary to create the assignment criteria. For detailed information about configuring assignment attributes, read Siebel Assignment Manager Administration Guide. The tasks to create the Opportunity ZIP Code assignment criteria are:
NOTE: Defining assignment criteria is only necessary when the predefined assignment criteria do not meet your organization's business needs. The tasks are summarized here to give you an idea of the underlying configuration that supports the subsequent sections of this chapter. |
| Developing and Deploying Siebel eBusiness Applications |
