Developing and Deploying Siebel eBusiness Applications > Introducing the Business Case >
Goals and Scope of Developing and Deploying Siebel eBusiness Applications
This book presents an actual implementation of Siebel applications at a fictitious company. The goal is to learn by doing. If you follow the procedures in this book you will have a functioning implementation (without the data) that has some very typical customizations that are easy to complete. These customizations will give you a taste of what is possible; it does not delve into every conceivable customization you may wish to make. However, each customization topic provides cross-references to more information for those who wish to expand their knowledge. This book also presents the basic strategy you should take to plan, design, and implement Siebel applications for your specific requirements. By following how this strategy is applied to NREC, you can learn how to apply it to your company. Again, cross-references are supplied for each element of the strategy so you can get more detailed information where necessary.
