Developing and Deploying Siebel eBusiness Applications > Getting Started with Siebel Tools > The Configuration Process > Testing ChangesWhen you have compiled objects into a new repository file, you can see the results of your changes in the client application. Typically developers set up a Mobile Web Client on their machine to use for testing and point the Web Client to the repository file that has been recompiled with configuration changes. NOTE: Make sure the correct SRF file—the one you compiled your changes to—is defined for the application to test. You can check this by verifying the value of the repository file parameter in the application's configuration file. This type of testing is considered to be Unit Testing, which is one element of an overall testing strategy. Registering New Views in the ApplicationWhen you add a new view to an application, you must make it visible in the client application before you can test it. You do this by registering the new view in the application using Administration - Application > Views and then associating it to a responsibility. If you are working with existing views, these steps are not necessary. The views are already registered in the application. To register new views in the application
To associate views with a responsibility
Verifying Your ChangesAfter you have made any new views available in the application, you can log in to your Web Client application to verify the results of your configuration changes.
| Developing and Deploying Siebel eBusiness Applications |
