Developing and Deploying Siebel eBusiness Applications > Getting Started with Siebel Tools > Using Siebel Tools > Setting Tools OptionsThere are several options in Siebel Tools that you can set to facilitate your configuration work. These options are available by choosing View > Options, and then choosing the tab for the options to configure. Some of the options are described below.
| Developing and Deploying Siebel eBusiness Applications |
