Developing and Deploying Siebel eBusiness Applications > Getting Started in the User Interface Layer > Configuring NREC's Activity AppletsTo configure NREC's applets you add and remove fields from the user interface, reposition controls, and modify text labels. After completing the procedures, you compile and Unit Test your changes. |
| Developing and Deploying Siebel eBusiness Applications |
