Developing and Deploying Siebel eBusiness Applications > Getting Started in the User Interface Layer > Creating Strings > Creating Symbolic String ReferencesYou create new symbolic strings in Siebel Tools. Symbolic strings created by Siebel Systems are included in the Symbolic Strings project. All custom symbolic strings should be created in your custom projects, for example the NREC Configuration project. NOTE: To be able to create symbolic strings, the EnableToolsConstrain parameter in the tools.cfg file must be set to FALSE. The Symbolic String object is hidden by default. To work with symbolic strings you must make it visible. To expose the Symbolic String object
Some of the customizations you make for the NREC project involve adding new fields or changing the names of existing fields. You make these changes by adding new symbolic strings or by editing the Symbolic String Locale of an existing string. To get started on this effort, add the new symbolic strings as shown in the following table. Notice that as you create each symbolic string, a Symbolic String Locale record is automatically added that has ENU as the language. This is because the Siebel Tools language mode is set to ENU. |
| Developing and Deploying Siebel eBusiness Applications |
