Developing and Deploying Siebel eBusiness Applications > Modifying the Look and Feel of the Web Client > User Interface Elements >
Source Control for Web Template and Related Files
Siebel Web templates and supporting files such as graphics and cascading style sheets are not stored in the Siebel repository. They are stored under the root directory of your Siebel installation. Because these files are outside a Siebel repository they are not controlled by the Siebel Tools Check In and Check Out Process. If multiple developers are modifying files outside the repository, you should use a third-party source control application to make sure developers do not overwrite each other's work. For the locations of Web templates and supporting files, read Location of Siebel Web Templates and Related Files.
