Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the House Detail - Appraisals View > Adding the Appraisals Business Component to a Business ObjectBusiness objects group related business components together. They also gather the Link objects that associate two business components with one another. Generally, business objects correspond to a screen in Siebel applications. For example, the Opportunity business object is analogous to the Opportunities screen. Internal Products business object is the business object on which the Houses screen is based. You must associate the Appraisals business component that you create, as described in Creating the Appraisals Business Component, to the Internal Products business object. To add the business component to a business object
| Developing and Deploying Siebel eBusiness Applications |
