Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the House Detail View > Configuring the Internal Product Business ComponentAfter you have applied the extension columns to your local database schema, you can add the fields to the business component that will use the columns to store data. In the NREC example, you add fields to the Internal Product business component. Additionally, you need to modify specific properties of the business component so users can update records. The following procedure uses the square feet attribute as an example. To complete the NREC example, you need to add fields for the attributes listed at the beginning of this section as described in Configuring the House Detail View. To add fields to the Internal Products business component
To change the default properties of the Internal Products business component
| Developing and Deploying Siebel eBusiness Applications |
