Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the House Detail View >
Creating the House Detail View
NREC wants to create a new view to display the Product List and Product Form Applets. They want to have the Products List Applet on top and the Products Form Applet below. This type of view is the standard list-form view. Use the View Wizard to create the view using the applets modified in the previous sections. To create a new view
- Choose File > New Object.
The New Object Wizards appears.
- Under the General tab, select View and then click OK.
The New View wizard opens.
- Complete the wizard using the information from the following table.
Project |
NREC Configuration |
Name |
NREC House Detail View |
Title |
House Detail View |
Business Object |
Internal Product |
Web Template |
View Detail (Parent with Pointer) |
Selected Applets |
Product List Applet Product Form Applet |
The wizard creates the view and related objects.
- To review the results of the wizard, select the View object and select the NREC House Detail View. Right-click it and choose Edit Web Layout.
- In the Web Layout view, right-click and choose Preview.
- When done looking at the preview, choose File > Close.
NOTE: When creating views with special visibility properties, such as Organization, Manager, or Sales Rep, set the Visibility Applet Type property of the View object, not the View Web Template Item object. The only exception to this rule is the Home Page. Set the Home Page visibility using the View Web Template Item object.
