Developing and Deploying Siebel eBusiness Applications > Implementing Siebel Remote > Setting Up a New Siebel Remote User > Initializing a Mobile Web Client Local DatabaseThe volume of information that must be downloaded from the Siebel Remote server to initialize a mobile Web client's database is usually substantial. You should establish a LAN (rather than a modem or WAN) connection between the server and the mobile Web client for this process. Alternatively, the local database can be initialized from a CD-ROM or other media—if compressed files have been copied into the folder specified as FileSystem parameter. For more information about extracting to a CD, read Siebel Remote and Replication Manager Administration Guide. NOTE: To initialize a mobile Web client database, the TableOwner parameter in the CFG file must be set to Siebel (the default). To initialize the mobile Web client database
To initialize the mobile client database during login
After the initialization completes, Chris Strong's laptop is ready for use in the field. Chris Strong needs to resynchronize with the Siebel Remote Server on a frequent basis. Instructions for this process are included in the next section, Synchronizing a Mobile Web Client. There is an auto synchronization option to help maintain the frequency of synchronization. |
| Developing and Deploying Siebel eBusiness Applications |
