This chapter provides you with an overview of a typical installation, using NREC as an example. It tells you the different environments to set up to support the implementation process and then describes the hardware and software NREC installed in each environment. The example gives details, such as the machine names on which products were installed. This chapter does not provide you with installation instructions. For each product mentioned in the following sections, there is a cross reference to where you can find detailed instructions.
