Developing and Deploying Siebel eBusiness Applications > Pick Lists, Drilldowns, and MVGs >
Testing the Configuration Changes
NREC's testing plan calls for periodic integration and regression testing. These tests are necessary to make sure that the changes you have made up to this point do not prevent previously existing features from working, and that the application still can interact with other applications and products. NREC's test plan makes sure these checks happen at specific strategic intervals in the configuration process. In the event a test fails, NREC can quickly locate the faulty configuration change and make the appropriate modifications. If these tests are performed too infrequently, then troubleshooting errors may be a major effort.
