Developing and Deploying Siebel eBusiness Applications > Pick Lists, Drilldowns, and MVGs > Configuring Pick Lists > Constraining a Pick ListYou can filter a pick applet to display only records that have field values that match corresponding fields in the originating business component's records. For example, you can constrain the Opportunity pick applet, configured in the previous section, to display only the opportunities for the account associated with the activity. To constrain a pick list you create another pick map with a Constrain property set to TRUE. This pick map defines fields on the originating business component and a field on the pick business component. These two fields must match for the record to be displayed in the pick applet. You can create more than one constrain pick map. Constrain pick maps do not copy the values of the field from the originating business component to the pick business component. They serve as a filter to determine which records appear in the pick applet. Following the NREC example, you constrain the list of records displayed in the Opportunity Pick Applet based on the Account field. To create a constrain pick map
| Developing and Deploying Siebel eBusiness Applications |
