Developing and Deploying Siebel eBusiness Applications > Required Application Administration Tasks > Registering Partners and Creating Partner Organizations >
Registering Partners and Promoting Them to Organizations
NREC registers each partner and then converts it to an organization within the NREC company structure. To register a partner and then promote it to an organization
- From the application-level menu, choose Site Map > Administration - Partner > Approved Partners.
The Approved Partners view appears.
- In the Approved Partners list, click New to enter a new record representing the partner. For example, enter San Francisco Real Estate.
A Partner form appears.
- Save the record.
The record is displayed in the Partners list.
- Click the Register button.
A form appears where you can select the Organization flag, which automatically promotes the partner to an organization.
- Select the Organization flag and enter NREC as the parent organization.
The partner is moved to the Registered partners list and an organization is created for the partner as a child of the parent organization—NREC.
