Developing and Deploying Siebel eBusiness Applications > Required Application Administration Tasks > Defining Company Structure > Setting Up DivisionsDivisions belong to organizations and are used to record addresses and to maintain default currencies. User reporting structures are defined by their parent position, but their country of operation and currency are defined by their division. To implement Siebel eBusiness Applications, you must have at least one division set up. A division is automatically created when you create an organization. For example, the NREC division was created when you created the NREC Organization. To review the division created for your organization
| Developing and Deploying Siebel eBusiness Applications |
