Developing and Deploying Siebel eBusiness Applications > Setting Up a Developer's Local Database > Performing a Full GetAfter initializing a local database, you must populate it with a read-only copy of the projects and object definitions stored on the server database. This process is called a full get. A full get is equivalent to checking out every project from the server, however the projects are not locked and you cannot modify the object definitions until you check out a project from the server database or lock a project locally. For more information about the check in and check out process, read About the Local Development Environment. Having a read-only copy of the full repository on your local machine allows you to compile a Siebel repository file for your local database. This is required for testing changes locally. To perform the initial full get of every project from the repository
For more information about working with projects, read Using Siebel Tools. |
| Developing and Deploying Siebel eBusiness Applications |
