Developing and Deploying Siebel eBusiness Applications > Setting Up a Developer's Local Database > Associating ResponsibilitiesResponsibilities determine which views users have access to. For developers, the responsibility should include access to the views necessary to perform testing and development tasks. The easiest choice is to assign developers the Siebel Administrator responsibility. It is already defined as seed data and it provides access to every view. Because the Siebel Administrator responsibility is already defined as part of seed data, you do not need to create a new one. You can associate the users to this responsibility when you register the developer as an employee in Setting Up Developers as Siebel Employees. An alternative to using a predefined responsibility is to create your own. For more information about responsibilities, read Applications Administration Guide. |
| Developing and Deploying Siebel eBusiness Applications |
