Developing and Deploying Siebel eBusiness Applications > Using EIM to Load Data Into the Test Environment > Disabling Logging Before Initial LoadsBefore performing an initial load through EIM, it is a good idea to disable transaction logging to improve EIM performance. Disabling transaction logging consists of disabling the Docking: Transaction Logging system preference. CAUTION: Do not disable Docking Transaction Logging if you have active mobile clients. Otherwise, the server database and mobile client databases will not be synchronized after the import. To synchronize them again, you need to again extract the database for each mobile client, and run database initialization on each client. For more information on synchronization, read Implementing Siebel Remote and Siebel Remote and Replication Manager Administration Guide. To disable transaction logging
You can also change the transaction logging preference by changing the LOG TRANSACTIONS parameter in the EIM configuration file. |
| Developing and Deploying Siebel eBusiness Applications |
