Developing and Deploying Siebel eBusiness Applications > Using EIM to Load Data Into the Test Environment >
Checking the Results of the Data Import
Your EIM log file contains comprehensive status and diagnostic information about the import process. NREC's EIM log files are located in the siebel_srvr_root\log\server directory, the default. To review your import process
In addition, you can check the status of each row EIM tried to import by using the IF_ROW_STAT column. For more information, read Siebel Enterprise Integration Manager Administration Guide.
