Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component >
Updating the Business Object
Like any business component, a virtual business component must be grouped together with objects of similar focus using a business object. Now that you have a link defined for the Internal Product/NREC Renovations VBC relationship, you need to add the Renovation VBC business component to the Internal Product business object. To add the Renovations business component to the Internal Product business object
- Expand the Business Object object type.
- Select the Internal Product business object.
- Select the Business Object Component object type (child of business object).
- In the Business Object Components window, add a new record as shown in the following table.
Business Component |
NREC Renovations VBC |
Link |
Internal Product/NREC Renovations VBC |
The NREC Renovations VBC business component is added to the Internal Product business object.
