Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Exposing the Fields in the User Interface >
Adding the View to a Screen
The next step is to add the new view to a screen. For the current example, you add the House Details - Renovations View to the NREC House screen. For information about the Houses Screen, read Creating the Houses Screen. To add a view to a screen
- Add a symbolic string for the term "Renovations".
- Expand the Screen Object type.
- Select the NREC House Screen.
- Select the Screen View object type (child of Screen).
- In the Screen View window, add a new record using the properties as shown in the following table.
View |
House Details - Renovations View |
Type |
Detail View |
Parent Category |
NREC |
Viewbar Text |
Renovations |
Sequence |
30 |
Menu Text |
Renovations |
