Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component >
When creating a virtual business component you do not use the Business Component Wizard because it forces you to select a table on which the business component should be based and does not set the class to CSSBCVExtern. To create a virtual business component
- In the Object Explorer, select the Business Component object type.
- Right-click in the Object List Editor and choose New Record.
- Enter Values for the following properties as shown in the following table.
Name |
NREC Renovations VBC |
Unique name for the virtual business component |
Project |
NREC Configuration |
Choose a locked project |
Class |
CSSBCVExtern |
Provides the virtual business component functionality |
