Developing and Deploying Siebel eBusiness Applications > Siebel Business Process Designer > Creating a Workflow Policy >
Creating a Policy Condition
Now that you have defined the event that you want to occur as a Policy Action, you can define the conditions under which the action occurs. You do this by defining a Policy Condition. To create a policy condition
- Navigate to Administration - Business Process > Policies.
- In the Policies list, enter a new record.
For the current example, complete the fields shown in the following table.
Name |
NREC Opportunity Notification |
This name can be any name that is meaningful to you. |
Workflow Object |
Opportunity |
Choose this value because the action is based on changes to an Account field. |
Group |
NREC |
Because this group does not currently exist, you must create it. 1 Click the select button in the Group field.
2 In the Workflow Groups dialog box, click New.
3 Specify NREC in the Name field.
- In the Conditions list, enter the condition as shown in the following table.
- In the Actions list, enter the record as shown in the following table.
Action |
This is the name of the Workflow Policy Action you created in Creating a Policy Action. |
Sequence |
10 |
Sequence of the Actions. |
