Overview: Siebel Enterprise Application Integration > Custom Business Scenarios > About Data Across the EnterpriseBusiness processes often need to cross departmental or even enterprise boundaries. Because different organizations may be using different applications, you need a way to make sure one application can hand off the execution of a business process to the next application. This section describes two examples: B2B Integration and Siebel EAI and Integrating Legacy Data. |
| Overview: Siebel Enterprise Application Integration |
