Overview: Siebel Enterprise Application Integration > Siebel EAI Overview > About Siebel EAI >
Cross-Application Process Integration and Workflow Control
To achieve process-level integration between Siebel applications and external applications, the Siebel Business platform supports workflow control. You define the integration process using the Siebel Business Process Designer, which is executed by the Siebel Workflow Engine. The Siebel Workflow Engine is an environment that allows you to define and manage complex integrations. A business service can be a prebuilt component, such as a transport adapter and the Siebel Data Transformation Engine, or can be custom-developed at design time or run time using one of the Siebel Scripting languages.
