Overview: Siebel Enterprise Application Integration > Siebel EAI Overview > About Preconfigured Integration Solutions >
UAN Business Processes
Universal Application Network (UAN) business processes are architected to be application independent and allowing organizations to use their existing investments. Organizations have the flexibility to select from any vendor's offering and support their customers through best-in-class solutions. UAN solves the semantic problem through the use of common objects and prebuilt transformations to popular applications. UAN is built based on open industry standards, such as Extensible Markup Language (XML) and Web Services-enabling enterprises to avoid limiting your vendor choices and ensuring interoperability with other solutions. UAN also uses the infrastructure developed by integration server vendors.
