Integration Platform Technologies: Siebel Enterprise Application Integration > External Business Components >
About Overriding Connection Pooling Parameters for the DataSource
Overriding the connection pooling parameters for the DataSource is supported. If connection pooling is enabled for the component, but should be turned off for the data source, set to zero (0) the following:
- DB Multiplex - Max Number of Shared DB Connections (DSMaxSharedDbConns)
- DB Multiplex - Min Number of Shared DB Connections (DSMinSharedDbConns)
- DB Multiplex - Min Number of Dedicated DB Connections (DSMinTrxDbConns) parameters for the datasource
