Integration Platform Technologies: Siebel Enterprise Application Integration > Integration Objects > About the Structure of Integration Objects >
About Calculated Fields and Integration Objects
Calculated fields are inactive in the integration object when they are created. If your business needs require it, activate the calculated fields in the integration object. NOTE: Calculated fields are those integration component fields that have the Calculated flag checked on the corresponding business component field.
