Integration Platform Technologies: Siebel Enterprise Application Integration > DTDs for XML Gateway Business Service > Outbound DTDs for the XML Gateway Business ServiceThe following sections contain examples of DTDs representing the %methodName% request sent from the XML Gateway to the external application. DeleteThe following DTD is for the Delete request: <!ELEMENT siebel-xmlext-delete-req (buscomp, remote-source, row)> <!ATTLIST buscomp id NMTOKEN #REQUIRED> <!ELEMENT remote-source ( #PCDATA )*> <!ATTLIST value field CDATA #REQUIRED> InitThe following DTD is for the Init request: <!ELEMENT siebel-xmlext-fields-req (buscomp, remote-source?)> <!ATTLIST buscomp id NMTOKEN #REQUIRED > <!ELEMENT remote-source (#PCDATA)*> InsertThe following DTD is for the Insert request: <!ELEMENT siebel-xmlext-insert-req (buscomp, remote-source?, row)> <!ATTLIST buscomp id NMTOKEN #REQUIRED> <!ELEMENT remote-source (#PCDATA)*> <!ATTLIST value field CDATA #REQUIRED> PreInsertThe following DTD is for the PreInsert request: <!ELEMENT siebel-xmlext-preinsert-req (buscomp, remote-source?)> <!ATTLIST buscomp id NMTOKEN #REQUIRED > <!ELEMENT remote-source (#PCDATA)*> QueryThe following DTD is for the Query request: <!ELEMENT siebel-xmlext-query-req (buscomp , remote-source?, max-rows?, search-string?, match?, search-spec?, sort-spec? )> <!ATTLIST buscomp id NMTOKEN #REQUIRED> <!ELEMENT remote-source (#PCDATA)*> <!ELEMENT search-string (#PCDATA)> <!ATTLIST match field CDATA #REQUIRED> <!ELEMENT node (#PCDATA | node)*> <!ATTLIST node node-type (Constant | Identifier | Unary Operator | Binary Operator) #REQUIRED> <!ATTLIST node value-type (TEXT | NUMBER | DATETIME | UTCDATETIME | DATE | TIME) #IMPLIED> <!ATTLIST sort field CDATA #REQUIRED> UpdateThe following DTD is for the Update request: <!ELEMENT siebel-xmlext-update-req (buscomp, remote-source?, row)> <!ATTLIST buscomp id NMTOKEN #REQUIRED> <!ELEMENT remote-source (#PCDATA)*> |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
