Transports and Interfaces: Siebel Enterprise Application Integration > Java Message Service Transport > Configuring the JMS Transport > About the JMSSubsys Named SubsystemThe arguments to any method of JMS Transport may be supplied individually as properties of the input property set or as part of a named subsystem of type JMSSubsys. When invoking the JMS Transport asynchronously by starting a JMS Receiver component, the arguments must be supplied by way of a named subsystem. This subsystem supplies all of the necessary parameters for any one of the three methods ReceiveDispatch, ReceiveDispatchSend, or SubscribeDispatch. The parameters for the three methods are ConnectionFactory, ReceiveQueue, SendQueue, Topic, SubscriberIdentifier, ReceiveTimeout, JMSType, JMSPriority, JMSExpiration, JMSDeliveryMode. In addition, this subsystem has a property JVMSubsys, which can be given the name of the JVM subsystem instance to use. The default value is JAVA. Therefore, if the property JVMSubsys is not explicitly given a value, there must be a properly configured instance of the type JVMSubSys named JAVA. |
| Transports and Interfaces: Siebel Enterprise Application Integration |
