Transports and Interfaces: Siebel Enterprise Application Integration > Using Siebel OLE DB Provider > Installing the Siebel OLE DB Provider > Viewing Siebel OLE DB InformationYou can verify proper installation and troubleshoot problems with connecting to, or running queries with, Siebel OLE DB Provider and a Siebel data source. To view Siebel OLE DB information
About Siebel OLE DB and Multivalue FieldsSiebel allows you to create rowsets that contain multivalue fields (MVFs). However, when the rowset is issued in an OLE DB consumer such as MS Excel, only the first child record in the Siebel MVF field will be returned. For instance, if you create a rowset based on the Opportunity BC and you add the Product MVF to the rowset, when you use the rowset in MS Excel only one record will display for each opportunity. The Product field or column will contain only the first product in the Multivalue fields list of products for the opportunity. |
| Transports and Interfaces: Siebel Enterprise Application Integration |
