Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using the Siebel Data Mapper > Creating Data Maps >
Determining Required Maps
The Integration Object Browser lists the existing integration object maps. Use this browser to determine which maps you need to create.
To determine which maps to create
  1. From the application-level menu, choose View > Site Map > Integration Administration > Data Map Browser.
    The Integration Object Map appears.
  2. Query for the integration objects you want to map.
