Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using the Siebel Data Mapper > Creating Data Maps >
Creating Integration Field Maps
You define the integration field map between your source and target fields using the Integration Field Map form. To define a integration field map
- Create a new record in the Integration Field Map list.
- Provide the following fields:
- Target Field Name. Name of the field in the Target Component where the value will be assigned.
- Source Expression. An expression that is used to calculate a value for the Destination Field. See Source Expression for details.
- Click Save.
