| Bookshelf Home | Contents | Index | PDF |    |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > XML Property Set Functions > ExamplesThe following example converts a <letter> to a <memo>. NOTE: The input letter in this example is slightly different from the previous example. <letter The conversion function converts this to a memo format, as follows: <memo> The map function that performs this conversion is: function ConvertLetterToMemo (xmlPropSetIn, xmlPropSetOut) |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
