Siebel Enterprise Integration Manager Administration Guide > Deleting Data > Editing the Configuration File for Delete Processing > Deleting Rows from Extension TablesYou cannot delete a row from one-to-one extension tables (*_X type) without removing its parent row. For example, to remove a row from S_CONTACT_X, you must drop the parent row from S_CONTACT. If you have to get rid of data in an extension column, update it with NULL by setting NET CHANGE = FALSE in the configuration file, and if necessary, use ONLY BASE COLUMNS. |
Siebel Enterprise Integration Manager Administration Guide |
