Siebel Enterprise Integration Manager Administration Guide > Exporting Data > Checking Export Results >
Viewing a List of Exported Rows
You can verify export results by checking a list of exported rows, as described in the following procedure.
To view a list of exported rows
  • Query the appropriate EIM tables for rows whose if_row_batch_num equals the batch number for the export.
    The value of if_row_stat should be exported.
If error flags, SQL trace flags, or trace flags were activated for the EIM process, you can also use the trace file to view the results of the EIM process. For more information on viewing the trace file, see Viewing the EIM Log File.
