Siebel Enterprise Integration Manager Administration Guide > Importing Data > Updating the Siebel Database > Fields That Cannot Be UpdatedYou cannot update system fields. All Siebel system fields are fields reserved only for use by Siebel Systems Inc. for internal Siebel processes. They are not to be populated with customer data. The following are reserved system fields that cannot be updated: |
| Siebel Enterprise Integration Manager Administration Guide |
