Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Importing Data > Preparing the EIM Tables for Import Processing > Required Initial Values for Special ColumnsEach row to be imported must contain the data you want to import and the appropriate values in the following columns: ROW_ID. This value, in combination with the nonempty contents of IF_ROW_BATCH_NUM, must yield a unique value. IF_ROW_BATCH_NUM. Set this value to an identifying number for all rows to be processed as a batch. IF_ROW_STAT. In each row to be imported, set this column to FOR_IMPORT to indicate that the row has not been imported. After processing, if certain rows were not imported due to a data error, you should change:
For more information on special columns, see EIM Table Columns. |
Siebel Enterprise Integration Manager Administration Guide |
