Siebel Enterprise Integration Manager Administration Guide > Importing Data > Editing the Configuration File for Import ProcessingThis section describes the header and process sections that you need in the EIM configuration file to properly configure EIM for an import process. For general information on the EIM configuration file, see EIM Configuration File. Before import processing begins, you must change the configuration file to support this function. Such changes include:
CAUTION: To prepare for recovery in the event of an unexpected problem, back up your existing database before you begin an import process. |
Siebel Enterprise Integration Manager Administration Guide |
