Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports >
Importing Multiline Fields
When importing multiline fields, such as addresses, you should use CHR(13) and CHR(10) for the field to be displayed as a multiline field. Otherwise, the following warning may be displayed in the GUI:
You have tried to modify a group of fields that may have more than one value. To edit or add field values in this group, please open the first field in the group by clicking on the multivalue field control.
