Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Importing Data > Checking Import ResultsWhen an import process ends, you should carefully check the results to verify that data was successfully imported. During each import process, EIM writes comprehensive status and diagnostic information to multiple destinations. This section explains how to use this information to determine the results of the import process and is organized as follows: |
Siebel Enterprise Integration Manager Administration Guide |
